Old 05-30-2016, 03:16 PM
CubDieselFan's Avatar
Default Work Benches
I am going to finish my work bench this week, I hope. I have the frame done, just need to order the top. I am going with 1/4" or 3/8" plate depending on cost. Let's see some pictures of your work benches.
Old 05-30-2016, 08:07 PM
john hall's Avatar
There's so much junk piled on mine there is no way you can see the bench!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-30-2016, 08:26 PM
All mine are piled up like John's.....but one is simply a household door with the hinges screwed to the wall and two 2x4s for legs.
Old 05-30-2016, 08:52 PM
I have one of those as well, but mine is on saw horses.
Old 05-30-2016, 09:31 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I plan on redoing the interior of my pole barn this summer. I need ideas! My Dad built this barn in 1973 and rigged up what he called a "temporary" work bench. It is still there! I bought the place from the estate a few years back and want to make the barn a very practical Cub Cadet fun center..including a....Cub Cadet themed bar!
Queen Of The Quietlines!
Old 05-31-2016, 05:26 PM
I have two built from 2x4 frame, MDF on top with sheetmetal on top of the MDF.
Old 05-31-2016, 06:43 PM
bocephus1991's Avatar
Mines a mess too! Need the clean up and put some stuff away! I'm bad about that. I'd go with 1/4" plate. 1/8" if you want. That's my 2cts!
Brian
Old 06-01-2016, 11:43 AM
i have a friend who works for otis elevator....you wouldnt believe what great bench tops elevator doors can make...
Old 06-02-2016, 09:56 AM
Berwil's Avatar
Berwil Berwil is offline
Mine is cluttered as well, but I'm not ashamed. The top is made from solid core doors I "salvaged" from a local school being renovated (I pulled them from the dumpster before I left the jobsite). It is very solid and takes a beating without ringing like pounding on a metal table. I have a separate 2'x3' piece of 1/4" steel I set on sawhorses for welding projects. I would end up setting the clutter on fire if my main work bench was also my welding table.
Bill
Old 06-02-2016, 10:55 AM
SGragg SGragg is offline
Inactive Member
Mine has a solid core door for the top. I also added 1/4" Masonite on top of that. When the hardboard gets nasty enough, I'll replace it. Works well.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
