Old 06-12-2016, 08:32 AM
richmondcadet richmondcadet is offline
Default Clutch issue
Ok let's first say I've been messing with cadets since 1968. I've owned well over 50 of all different models and I always have done my own work. A few years back I liquidated all my cadets. Recently I picked up a little model 73 and my drive shaft won't stop when it's in neutral.
Here's what I've seen and done.
The clutch plates are clean a flat, the clutch disc looks almost new, the drive plate bearing is clean and greased. The drive plate pins are hardly worn, the teaser spring and throw out bearing are very good and turn freely when not engaged. I drilled a hole in each pressure plate to relieve and air pressure issue.
It seems that it comes down the the anti rattle springs are holding the clutch disc to the drive plate and causing the issue.. Without the springs there is no issue. Without the springs of course I get the rattle of the clutch disc.
Before I pull the entire driveshaft and clutch assembly out any ideas?
Thanks
Old 06-12-2016, 08:54 AM
twoton twoton is offline
Is it possible that your drive plate/three pin driver is warped? If the spirol pins are not true to the holes in the friction disc this could result in some parasitic drag. Especially if all the parts are new and have not had a chance to 'wear in'.
Old 06-12-2016, 09:06 AM
Excellent point. Will check. The three pin driver.
Old 06-12-2016, 09:09 AM
I think you mean that it still won't stop when you press the clutch pedal in? It will still spin in neutral
Old 06-12-2016, 09:48 AM
I use only one anti rattle spring.that is what I do.
Old 06-12-2016, 11:26 AM
Yes. It spins when the clutch is depressed.
Old 06-12-2016, 11:32 AM
http://www.onlycubcadets.net/forum/s...&postcount=131
Old 06-12-2016, 01:22 PM
Removed two anti rattle springs and left one. Works fine no disc chatter and the driveshaft is no longer spinning while the clutch is depressed.
Issue resolved.
