Old 06-16-2016, 11:38 AM
Bumpy55 Bumpy55 is offline
Default 1811 issues
I have a 1811 that I picked up for almost nothing but is developing problem as I try to use it. It starts running rough as soon as you try to push it a little, it also doesn't seem to want to charge and last but not least the PTO won't engage unless I hold it on. I have looked at the key switch and made sure I had good connection and also the regulator. I am open to all suggestions. Thanks
Old 06-16-2016, 11:57 AM
JLM78 JLM78 is offline
Did you clean the carbb ? How many Volts is it charging ?
Old 06-17-2016, 11:41 AM
Don't think it is the carb because it come and goes but I'll hit it with some carb cleaner to be sure. I saw on a another post that if it not charging and battery is down it will keep the PTO from latching in.
Old 06-17-2016, 12:20 PM
Do know if it has safety Swich under the sent ? The clutch will do the same thing bad swich or a broken wire broken . I think you need 12 voits keep it working .
