Old 05-17-2010, 01:52 PM
austin neuschafer austin neuschafer is offline
Default my 1862 plow project. some help needed and pics
ok. I have a 1862 that I want to make a front plow work on. from what I understand it is a spread/wide frame. I believe something in the front mounting is different cause of the mower deck. also I need to repair the undercarriage cause it has some fatalities and would like to add a crossbrace like what the later ones had if someone can provide a measurement of what the factory ones had. I know Ineed a lift rod, but that will be about the easiest thing probably
Old 05-17-2010, 03:29 PM
update. figured out how to mount it. anyone have good pics of the undercarriage?? as i have do a bit of bending and reinforcing
also pics of the factory lift bar if anyone has it laying around, otherwise I will make one anyways thru trial and errror
