Old 07-08-2016, 09:24 PM
Nightow1 Nightow1 is offline
Default LT-1050 PTO issue
Have a LT 1050, the pto clutch will disengage at random.
I mowed with it for around 90 mins and it kicked out 7 times, but would engage once i pushed the switch bck in and out. Any suggestions?
Old 07-08-2016, 11:18 PM
Berwil's Avatar
Berwil Berwil is offline
My first thought is a loose connection/failing safety switch in the pto relay hold down circuit. A momentary interruption in the hold down circuit would let the pto drop out, but it would fire back up immediately when you reflip the switch. Did you notice a pattern that it cuts out over bumps?
Bill
