I have a 1641 with a 42" snow blade (not mounted). The blade has a mounting package 377 (190-377-100) attached to the blade but all of the attachment threads I read say it should use a mounting package 316 (190-316-100). Can either mounting package be used on the 1641? The tractor serial number is 843814. Also does anyone have an operating/install manual for this blade?
Any help would be greatly appreciated. |
There is a different part number between the two sub-frames due to the taller super-steer axle, but the main difference is tractors after serial # 821,101 did not have a lift bracket built on the rock shaft. You will need Cub part # 719-3093. I think the sub-frame will work but you may have to play with the lift rod length.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
Thank you for the information. If I was to buy the frame what would a fair price be?
