Old 07-12-2016, 07:40 PM
Wbrech Wbrech is offline
Default Transaxle oil
So out of curiosity what oil are you guys putting in the tranny of your pullers?
I've heard several opinions from 2 quarts of ATF to 3 quarts synthetic motor oil to plan old hy-train. Just wondering what to put in this thing. I'm running dart carrier and all Midwest internals. i figure I've put enough money in this thing, might as well put the best lube I can to it.
Old 07-12-2016, 08:00 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I'm not a puller, but if I were, I would use 30 wt nd break-in oil. Cheap store brand at that, just change it often.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 07-12-2016, 08:27 PM
If I had that kind of money in it I would run something synthetic.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-12-2016, 09:38 PM
austin8214's Avatar
I prefer to use something 30wt or thicker. ATF doesn't provide the protection needed in my opinion.
Old 07-13-2016, 07:50 AM
mickb72 mickb72 is offline
Default cub
I/ve always used a gallon of ATF I had one that came with a clear hydralic oil. Jack oil? Mike
Old 07-13-2016, 05:25 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I just use 2 qts synthetic atf
