Old 07-14-2016, 02:27 PM
ljlandscaping ljlandscaping is offline
Default Tiller on Original
I would like to put a tiller on my O with pto kit, two questions. What size belt? Is it the same size as a normal narrow frame belt also which mule drive would I use the normal deck one or the other one?
Thanks
Tractors: 4x O's, 70, 73, 100, 102, 125, 147, twin stick 1250, 782,
Attachments: T38 Mott, Danco RD2000, RD300, Amerind Mackassic Chippah, 2x Brinly, IH rear blade, IH rear rake 2x Rear ptos, IH #1 tiller, EZ-Rake Dethatcher, Wind Breaker, power angle plow 54",
Old 07-14-2016, 09:07 PM
The original was the only IH cub cadet you could not put a tiller on like the rest of them,you needed a tow behind Planet JR. to do the job.
But with a torch and a welding setup,anything is possible.
Old 07-14-2016, 11:20 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default tiller
If you put the front later style PTO on an Original you can put a tiller on Geezer had one on one of his Originals
Old 07-15-2016, 01:54 PM
olmstead25 olmstead25 is offline
You can put the tiller on even if you do not have the PTO kit, it is just not very safe. As far as the mule drive the one for the deck should work fine. The belt I suggest mounting everything up and measuring it with a piece of string or something like that and just buying a belt that is close. I think most places will allow you to return it if it is wrong so long as you never "run it" with the belt. I just measured the difference between the original and 100 for length and it might be close. It would be a good place to start. Just make sure you do not run it unless you know you can get the belt tight.
MO
Matthew 7:21“Not everyone who says to Me, ‘Lord, Lord,’ will enter the kingdom of heaven, but he who does the will of My Father who is in heaven will enter.
Old 07-15-2016, 02:25 PM
Merk Merk is offline
X2
I saw Geezer running a tiller on a Original at a plow day several years ago.
Project Uncle Dick
Cub Cadet 70
Old 07-15-2016, 04:41 PM
I agree, he had a tiller on one, so it can be done.
Old 07-15-2016, 10:24 PM
X2
Well I'll be dipped in shi*,It can be done
Old 07-17-2016, 02:30 PM
Yea I have the pto kit along with both mule drives and was wondering which I should use along with belt length etc
Old 07-18-2016, 02:49 AM
What does "both mule drives" mean?
Since IH never offered a tiller set-up for an Original, you will have to figure out the belt length for yourself. Unless of coarse someone here has done this before.
The closest guess you will probably find is 13/32" X 141-7/8" (The correct belt size for the Narrow Frame tractors with tillers). As an Original IS NOT a Narrow Frame tractor, this is most likely not the correct belt, but it's a place to start.
Do what the guys have told you, get it mounted and everything set up, then wrap a rope through the pulley system and measure the length of the rope. That will still probably not get you the exact length, but you'll be a step closer.
