Old 05-18-2010, 11:18 PM
Default First try at plowing........Is my setup wrong or worn out?
I had a few spare minutes tonight so I popped the sleeve hitch on the 122 and installed a plow I picked up at the flea market last year.. Well, it was not a success... I couldn't plow straight to save my life, and it only would go into the sod and clay Texas soil about 2-4 inches most of the time... Also I could not have my right wheels in the furrow and plow another furrow without skipping about 4-6 inches, so I had to run over freshly plowed dirt with my right wheels....
Here's a couple of pics of the setup.. do you guys see anything wrong with it??? I am used to plowing with an 8 N Ford and a dearborn plow, this brinley thing is different.
I was using first gear, I tried second but as it started to dig the clutch would slip...which this tractor has always had as a problem... Probably need o rebuild my clutch soon.
I know I don't have a coulter wheel... but that can't be it can it??
Old 05-18-2010, 11:27 PM
Use the middle hole on the yoke. You have nowhere near enough "point" on the plow. Put the left side of the tractor on 5-6" of wood blocks, set the plow on the ground, and adjust it such that the bottom is flat on the ground.
Old 05-18-2010, 11:32 PM
So you are saying I need a new point then...any idea if anyone has them for this particular plow? or do I need to get out the arc welder and some hardfacing rod...(A LOT of HF rod..)
Old 05-19-2010, 12:03 AM
No, it's an adjustment, the procedure was in my last post. "Point" refers to the angle between the plow bottom and the ground, more or less.
Old 05-19-2010, 12:16 AM
OK, got ya.. Thanks!!
