Old 07-22-2016, 08:59 AM
cubcadetguy123's Avatar
cubcadetguy123 cubcadetguy123 is offline
Default Questions
Ok guys, I have a few more questions about the little gems. Any help is better than nothing, so thanks in advance.
1.) what weight oil is used in the 3 speed rear end. Is it just same old rear end grease.
2.) can you get new clutch disks for these things? I can't seem to find one. Maybe I'm just not looking in the right places.
3.) what color were the grilles on the 73? I have seen them silver, black and white.
4.) are the headlights used in the 73 option a special brand and/or number?
1970 Cub cadet 73
Old 07-22-2016, 09:17 AM
RedHawCadet RedHawCadet is offline
For the rear end you can run sae 30, or hytran. The clutch disc are easy to find eBay or your local cub cadet dealer sells them. As far as the grill color my 73 grill is silver, not sure if it was that was factory but it appears to be original. The headlights as I'm sure you know were an option but I believe we're made by cub cadet.
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 07-22-2016, 10:43 AM
Terry C's Avatar
Terry C Terry C is offline
Rear end grease is too heavy won't let you shift in the cold. HyTran is best
73s that I have seen are silver
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-22-2016, 10:47 AM
Sorry, you can also check with the sponsors above for your clutch parts they have them.
Mark
QA42 snow thrower
42in front blade
Old 07-22-2016, 11:11 AM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
You can use the parts lookup at
http://www.cubcadet.com/equipment/cu...vice-and-parts
You can order a lot of parts directly from Cub Cadet still. You can also use the sponsor links at the top of the page. It even gives you bolt sizes for a lot of things, so you can use it for a lot of things.
Goto the technical forums and get the owners manual and service manual for your tractor.
As for rear end. The definitive consensus I've found on here is that official Case-IH Hytran is the best. You get mixed responses about HyTran equivilents. The same as you get when asking about any aftermarket v oem part. Use your best judgment there. IMO if it says it meets specs, then it should perform the same. Case is a big company and would be serving cease and desist orders if a company as large as TSC was selling a knock off that didn't go through the proper procedures to certify something as compliant.
As for headlights, use the tool to look them up. I know on my 149 they are a standard size available anywhere. Can't remember off the top of my head, but they aren't Cub specific.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 07-22-2016, 04:51 PM
Thanks guys!
1970 Cub cadet 73
Old 07-22-2016, 05:14 PM
I'm pretty sure the grills were zink coated.
Headlights are 4411's (industry standard number) I keep thinking GE was the brand that came with a new Cub.
Old 07-28-2016, 08:57 AM
If you don't mind my asking, what is zinc coating? I have never really heard of that, but if that's what they were, I want to do it up original.
1970 Cub cadet 73
Old 07-28-2016, 09:33 AM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
aka galvanized
Old 07-28-2016, 10:00 AM
Better get out your wallet, there's plenty of spray paints that replicate the zinc coating.
Pap's 100
Restored 108
1211 Dual Stick
1050
