Old 07-28-2016, 02:23 PM
joem789 joem789 is offline
Default 1440, a plow, and a hitch
Hi. This is my first post here. I have reading all the great information on this forum that pertains to my CC. But I cannot seem to find all of it.
I have a 1440 that works well. I am contemplating the idea of getting a moldboard plow for my field in the back. I think the 1440 could handle it since my soil isnt that tough to dig. But I need to figure out how to get it hooked up first of all. I don't know much about hitches. I have heard that they usually hook up using a sleeve hitch. But have also heard that the 1440 only has a 3-point and an adapter kit. Although it seems that the actual official parts are either expensive or rare to find. There must be aftermarket parts to accomplish what I am trying to do which is:
1. Get the plow connected to the 1440.
2. Have the ability to raise and lower the plow.
Is there some type of kit to make use of the manual lever on the mower for raising implements? I have seen that there is a universal electric hitch that costs about $600 which is more than what I paid for the 1440. So thats out of the question. There must be a cheaper way to accomplish this.
Old 07-28-2016, 02:42 PM
There isn't aftermarket, and cat 0 3pt is what was offered on the 1440.
If you can fabricate, you could likely get a sleeve hitch (Cub Cadet 3 point) to work on your tractor. One off of a 682 may bolt right up, but you will need a different lower bracket because of the aluminum rear. You can those from xtreme. Still going to likely spend $300 plus the plow.
Old 07-28-2016, 03:50 PM
Cub offered a Cat 0 3 point that will fit a 1440. 388 3 Point Hitch w/Spring Assist, 190-388-100
http://www.cubcadet.com/equipment/AR...0-A/0064600001
I think Xtreme also offers a copy of the factory hitch but I'm not sure if they have a spring assist. You'll probably have to call and ask Aaron.
http://www.xtrememotorworks.com/Part...rts%20List.htm
Old 07-28-2016, 04:33 PM
My 1440 has a spring assist,but I guess you would have to remove it to use the hitch though,not sure.
Old 07-28-2016, 11:27 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
He does, but you need to specify the tractor when ordering. Have one on my 1864
1- 1200 in pieces
1- 1864 in pieces
Old 07-31-2016, 12:58 AM
I checked out the Xtreme website and I must say they have quite the selection of Cub Cadet parts. It looks to me like they would have everything I would need. I tried sending them a message a few days ago but got no response.
I notice that many of their parts state they only work on tractors "without PTO". Of course mine has PTO. So I don't really understand why that would be an issue. I am wondering if I could just get one of their brackets to bolt up on the frame so I can just connect a brinly style sleeve hitch and nix the 3-point set up? But I have yet to figure out how the manual lift spring connects to it all. Seems like the only drawback to CC's is the overwhelming selection of non-interchanging parts and lack of instructions.
Old 07-31-2016, 01:10 AM
the pto they are referring to is a rear pto, not the one on the engine. your tractor doesn't have a rear pto.
Pap's 100
Restored 108
1211 Dual Stick
1050
