Old 07-31-2016, 08:51 AM
cobra2411 cobra2411 is offline
Default Hydro transmissions - general questions
With older crappy lawn mowers and their aluminum hydro transaxles I'm a little leery about getting a mower with one.
Are there hydro's to avoid? I like the looks of the narrow frame tractors, but the slightly newer age wide frames are good looking too. So I probably would be looking at tractors in the late 60's and early 70's.
What should I look for if I consider one?
Also, how long did they still use the shaft drive transmissions similar to my 124 or a hydro version?
Old 07-31-2016, 09:04 AM
ironman's Avatar
ironman ironman is offline
I think you will get some good information if you can provide some ideas for its intended use (i.e mowing, plowing, tilling) and what your lot/acreage/terrain consists of. There are many different models, and just like people, some are better at one thing while udders are better on mothers.
Old 07-31-2016, 09:17 AM
Now I have to remember that one, it is udderly funny
( as I'm wiping morning coffee off the keyboard)
Old 07-31-2016, 10:06 AM
All the way through the cyclops series.
Old 07-31-2016, 10:13 AM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
And keep going up to the XT3 of today...but you'll have to pony up.
Old 07-31-2016, 10:16 AM
Well, they are still shaft drive but a completely different trans than used in the cyclops and before.
Old 07-31-2016, 11:54 PM
I can't tell you what ones to stay away from, but I can tell you that if you are looking for one of the older Cub Cadet lawn and garden hydrostatic drive tractors. you can not go wrong with a 123, 105, 125, 107, 127, 147, 109, 129 or 149 (made from 1966 to 1974).
Not that there is anything wrong with the later ones, but the Narrow and Wide Frame tractors are what you mentioned in your opening post.
Even though the hydro transmission housing in these models is aluminum (as are the later ones) these transmissions are nearly bullet proof. About the only way to break one is to tow it without releasing the relief valves.
Old 08-01-2016, 06:56 PM
CadetTommy's Avatar
CadetTommy CadetTommy is offline
Both of my hydros are great for mowing and pulling a trailer and lawn sweeper. They are smooth, powerful, and very fast if I want to go across the farm to dump chicken poop. They are both 1987 models, one is an 1811 and the other is a 1872 super, both have hours in the 400s.
'74 IHCC 108 - 38A, supersteer axle
'75 IHCC 1000 - 44A, Sears wheel weights
'87 CC 1872 and 1811 - Haban, 44C
'96 CC 1863 - 54GT
'79 JD 400 - 60" deck
"Projects" '67 123, '65 102, '71 126
Old 08-01-2016, 07:07 PM
No comment on anything newer than 1997 as I have no experience and don't want any.
All of the hydros I've owned started with the wide frame series, the quiet line, the 82 series and the Cyclops.
All of the Cubs that have the Sunstrand hydros were excellent, durable, snooth hydros when new. After 50 years of neglect, abuse and/or no maintenence, most are still running well.
The Hydro-Gear hydros are also good but they aren't as smooth or as robust as the Sunstrands.
I wouldn't make a distinction between a cast iron case and an aluminum case if I was using the tractor for domextic or residential use.
Old 08-01-2016, 09:07 PM
Any of the IH built hydrostatic cub cadets are bullet proof IMO. Keep fluid clean (filter changes) drive shaft fan installed, and it'll be fine for years.
