Old 08-02-2016, 06:32 PM
corporalk corporalk is offline
Default Solid ISO mount dimensions?
I would like to make my own solid iso mounts. Anyone have a dimensioned drawing?
I would also like to have a dimensioned drawing of the oil pan mounting hole pattern that attaches it to the cradle. I do not have any spare parts to measure and I am just getting started with the cub cadet tractors with my son. Dimensions that are reliable please.
Thanks!
Old 08-02-2016, 08:35 PM
JeffinPA has the dimensions. Oh yeah he makes them for sale.
Old 08-02-2016, 10:22 PM
Yep, Jeff's your man for solid mounts...
Old 08-02-2016, 10:34 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Yup, jeff all the way! He already did the home work, and it will be right!
1- 1200 in pieces
1- 1864 in pieces
Old 08-02-2016, 11:47 PM
bocephus1991's Avatar
I'd just buy them from Jeff, well worth the $ !
Brian
Old 08-03-2016, 02:50 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
^^ what he said.
He's a good guy too, he might share the dimensions if you'd like to give a DIY try. But for the price, unless you have a full machine shop, he's your guy.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 08-03-2016, 03:10 PM
I wouldn't, he makes money selling them. I have no issue with the guy making his own but he should figure it out for himself, no matter how many times I call Coke they won't give me the recipe.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-03-2016, 04:07 PM
vr4Legacy's Avatar
Eh. I get that. But these are pretty set dimensions, not a secret mix of special ratios of items.
You're paying for his effort and skills, not so much the fact that they are a proprietory dimension. Not many people have the skill or tools to make them.
But, I'd understand if he doesn't want to either.
Honestly, if you can't figure out the dimensions with a QL in front of you, it's probably best to buy a set you know are the right dimensions.
-Jason
Old 08-03-2016, 04:15 PM
Yep, I went through the same crap when I was making the rear-end braces. "Can you give me the dimensions so I can make my own" I can but I wont figure it out yourself just like I did then tell me how much you saved. Rant Over.
That's what I was going to say.... just not as tactfully as you did.
Figure it out on your own, or buy them from Jeff.
