Old 08-10-2016, 09:38 PM
BillZ BillZ is offline
Default Brinly plow advice
This is the Brinly plow that came with the Cub 129 I bought. I'm looking at pictures of other Brinlys and I think the po welded an extra piece of metal onto this plow. Why would he do that? Should I attempt to remove it?
My plan now is to restore the plow as well as I can, I've never done that before so any advice on what to look for and what to avoid would be appreciated.
It's rusty but I'm not sure if it needs to be sandblasted or if a brush wheel would do the job. All the elements seem solid. The Brinly decal is half gone so I'd need a replacement.
I 'd really like to get it looking good.
Old 08-10-2016, 09:39 PM
Another pic
Old 08-10-2016, 10:48 PM
bocephus1991's Avatar
I'd cut it off, probably for some kind of homemade jerry rigging going on there. Just cut it flush with the top beam of the plow. I'd use a sawsazz.
Brian
Old 08-10-2016, 11:37 PM
id cut it off, the yoke is on wrong also. here's the only pic i have of how the yoke should be.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-11-2016, 12:16 AM
I too would remove that bar, depending on where it's welded and how many welds there are will determine your plan of attack.
Try to avoid cutting/grinding into the original metal, so the job looks nice when it's finished.
Tags
brinly, plow
