Old 08-15-2016, 03:11 PM
Dirty Steve's Avatar
Default Cyclops dual hydraulic question.
I can not find much info about the dual hydraulic set ups for cyclops tractros. Cub Cadet Warehouse shows a front outlet kit with part number 759-3493A. Nothing comes up on the Cub Website with this part number. Took some pictures.
Wondering if anyone has a instalation manual or parts break down list?
Old 08-15-2016, 05:03 PM
spudder spudder is offline
If anyone has one, it would be Dave Harmon. He goes by ccpullin here. I've got an NOS kit that came from him. I have an early Cyclops service manual that has installation instructions.
It's pretty straight forward, I just added a used setup to a project tractor. Some lines are different if the tractor has a water cooled engine.
PM me if I can help you.
I bought a 1864, it's just grown from there. The Cubs have replaced old Chevys as my hobby/passion. The only car I have left is a '67 Chevelle wagon.
Seems like a good trade off. I can put five Cubs where one car sat and there are no titles or license to fool with!
Old 08-15-2016, 05:09 PM
Steve
Look in the manual I sent you. The info is in it. God do I have to do everything for you?
Old 08-15-2016, 05:56 PM
Contacted MTD. Form number 772-4100A delivered to me by E-mail.
Sam, if you are referring to the big Cyclops manual, I did not look there.
As soon as I get back to my work computer I will post the link here.
Old 08-15-2016, 06:12 PM
Sam, if you are referring get the the big Cyclops manual, I did not look there.
As soon as I get back to my work computer I will post the link.here.
Yep that would be the manual I was talking about.
Old 08-15-2016, 09:56 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Could just buy a valve and put ther rest together yourself
1- 1200 in pieces
1- 1864 in pieces
Old 08-16-2016, 04:56 AM
Was looking into that when I came across this machine from another member here. I bought it for parts including double hydraulics. The reason I wanted the instruction manual was to edjumicate myself just a bit on the workings before I dismantle it and do more harm than good. Then of course get it remounted right back onto my other tractor.
Old 08-16-2016, 07:42 AM
I hope this link works. I sent it to Admin so others may have access. Enjoy!
http://manuals.mtdproducts.com/manuals/772-4100a.pdf
Old 08-16-2016, 02:19 PM
Rescue11's Avatar
Did you put both valves on your tractor? Because then you could have 3 hydraulic valves!
1- 1200 in pieces
1- 1864 in pieces
Old 08-16-2016, 03:23 PM
Never thought of that. I had thought about putting the other valve in my 2284 and taking the existing dual lines to be copied. Outlets up front, middle lift, and rear outlets would be awesome!!! But what would I use rear outlets for....
I have not removed the hydraulics from the parts machine yet.
