Local scrap yard has a few air compressor tanks that I was thinking of making a yard roller. One is a 30 gallon tank, another is 60 gallon, 3rd is bigger than 60 but not sure what size. I was thinking 30 is too small. What's your thoughts?
________________________ Scot |
My roller is 48 inches wide and 24 inches tall. It weighs 920 pounds when full of water. I pull it with a IH Cub Cadet 100.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Just like pulling any other kind of load.
Depending on the lay of your land, don't try to pull more of a load than you can stop.
Water is 10 lbs per gallon, a 600 lb'er is prob as small as you'd want to go. I like the 900 lb size for a good effective roll. The 600lb'er could be good if you built it such that you had a top platform to load it with more weight such as blocks. Merck's 48" X 24" is perfect.
Too much weight wouldn't be a problem unless.........................
You have some hilly areas that could push/jacknife your tractor. Your tractor's brakes don't work well. See above. Your tractor has the spot brakes in the differential. You break a spirol pin in the drive line and you take off down the hill. You hit the brakes only to find out with those kind of brakes, one wheel rotates backwards and the other forward. In the meantime, hang on. Or jump before you pick up too much speed. |
PS. I have a safety chain from the roller axles up to the hitch in case something broke. I'm all hills here. My roller weighs about 5-600 lbs and if it got away from the tractor, it could take out a car in the driveway, house or garage.
Water is just above 8lbs per gallon.
8.34 |
My mistake. I work in Imperial and metric. Should have converted to US gallons.
My property is pretty hilly too. House/cars is at the top. I went back today & looked more carefully, the smaller one is 30 gallon & wants $40 for it. The two larger are both 60 gallon & both still have the compressor & motor on them, they wanted more than I wanted to spend. I'll wait, maybe they will separate them & sell tank alone.
Lol. I figured you converted wrong.
