I have a 46" GT deck on an 1811. The 1811 will not raise the deck high enough to raise the wheels off the ground. I've got the mule drive adjusted so that it should raise it high enough but maybe this deck is only for the cyclops series? I've got 3 different mule drives and all look the same (nothing bent up)... There is a little adjustment left on the mule drive but I doubt it will be enough...
982 with 3 PH, rear pto, front & rear hydrs & ps, 1772 w/3 point, rear PTO, 86, 2 Haban 60" decks, Haban 54" snow/dirt blade, Brinly Cat 0 Disk, 5' blade & 2 Cat 0 Plows, SpeeCo Cat 0 plow, Sears cat 0 Cultivator, Cat 0 CC 442 Tiller, 60” rear mower, 450 blower |
46GT is listed as a deck for the 1811. All I can think of is that you have the wrong lift links on it. Post some pics.
You may have sheared pins in your rock shaft. I have the same mower with 1862 (same lifting mechanism) with a similar problem.
46gt was made for the 1810 and 1811 series tractors. It will work on a 782D
they were not popular due to the height of the deck it will not raise very high. I like the deck for the lift it puts out. I use it with a trac vac for leaves in the fall. And to collect some grass clippings for the garden. Wear earplugs as they are loud. |
At one time, I had five tractors with the 46" GT deck. 1641's, 1860, 1862, and an 1810. All of them would get the wheels several inches off the ground except the one I have left on a 1863 which I keep around to use with an EZ Vac. The dealer told me the reason they were discontinued was because they windrowed the clippings too bad and that they will do but they sure suck up leaves.
I converted all my tractors I cut grass with to the 48" and 54" decks for a better cut and they raise just as high as the 46" they replaced. |
Can a person mount them to a super without modification to the mule drive?
A member here named Jibber has a 2182 with VERY low hours (less than a hundred original last year) with a 46 inch deck and non motorized 3 bag bagger on the rear. He may have some good insight regarding a 46 inch deck with a SGT.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 ![]() ![]() {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
How far down do you have your guage wheels set?
No mods, just move your subframe to the rear most holes on the mule drive.
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
Well, figured out my problem! Pin fell out of the cylinder!
That'll do it!
