Old 08-27-2016, 09:22 PM
cubcadetguy123's Avatar
cubcadetguy123 cubcadetguy123 is offline
Default Wheels and tires
I'm coming in on the home stretch with the 73 project. I'm almost ready to start assembly. It's now coming up about new tires. I want to get new ag tires all the way around. What are some of your thoughts on this? I'm using the skinny rims on the back and new tri-rib tires and rims on the front. What have you guys used in the past.
Also, I'm planning on putting the daul wheels on the back again. What is the correct way to mount dauls? I've seen a ring between the two wheels like a daton truck wheel, or a actual axle extension the bolts on to the wheel. Any thoughts on this?
1970 Cub cadet 73
Old 08-27-2016, 09:25 PM
if your going to be running duals id suggest deestone ags, the carlisle's are nicer but it will get expensive buying 4.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-30-2016, 09:33 AM
ambrola's Avatar
ambrola ambrola is offline
My 124 has Dee stones, were on it when I got it. They look good, and get the job done.
Old 08-30-2016, 05:48 PM
There isn't a "correct" and "incorrect" way to mount duals. Abrola has the spacers that bolt to the hub. They do provide true power to all of the rear tires directly, but the IH spacers are a challenge to find (at least for me they are, but probably not for my Uncle Lewy), and costly (around $200). I used the ring spacers on my O, which does not provide true power to all rear tires, but it does keep the mud/snow out of the inner rims and is quite less expensive around $35. I have reversed my inside rims to give a more stout appearance and allow a tighter fit for storage into my garage. It really is up to you on personal preference. Another factor is who will be on the tractor. My O does not have fenders and the tires are close to the driver, so I am very mindful of loose clothing when I ride it so it does not get caught up in the tire, so no fenders is not a good idea for little ones EVEN IF THEY ARE HELD AND WATCHED. Always think safety as you are equipping your tractor/implements.
Life is not about making the right choice, no one ever does. Its about making the choice right, so just consider safety and then application/use, along with what your budget is.
Here are some pics of my ride for your consideration:
Old 08-30-2016, 06:10 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Yup, definitely a fan of the deeststones. Only thing that kinda bums me out is that they aren't US made. Off topic but I like their front tri ribs better than any brand I've tried.I really like the looks of the duals, that is a tough looking 124. I do however like that Original with the tighter spacing that Cubcadet123 showed, solely for storage reasons. Good call on the safety aspect
-Rick
IH 782
IH 126
CCC 1863
