Old 08-29-2016, 12:36 AM
Billy(OH) Billy(OH) is offline
Default New to me 1782, issues and questions
Just picked up a 1782 Sunday afternoon with 530hr that look like sat out half its life but still in decent shape. I'm new to messing with the super garden tractors but worked with old gear drives a lot just wanted something bit nicer to mow the yard. It got a issue that don't make sense to me. When you go to start it you have to hold the pto switch in the on position before it will crank...wiring issue? Are they suppose to have a manual or electric fuel shut off? Mine is manual but it looks rigged up to me. Also the top ears of the exhaust manifold are all busted. And I wondered if its a common problem with them from the muffler hanging off of it
Old 08-29-2016, 04:48 AM
Dirty Steve's Avatar
Congrats on the one eyed Super smoker! Yeah, it sounds like you have some wiring issues. You need to get ahold of wiring diagrams and get started chasing the demons. You can try the sponsors at the top of the page for exhaust parts. Many things related to the engine are still available new through Kubota.
Old 08-29-2016, 06:33 AM
When you go to start it you have to hold the PTO switch in the on position before it will crank...wiring issue?
You could have (A) a bad PTO switch, or (B) Improper PTO Switch, or (C) Improperly wired.
Old 08-29-2016, 07:14 AM
Electric shut off is NLA, had the same issue with a 1782 I owned. Here are a couple threads that may help.
http://www.onlycubcadets.net/forum/s...ad.php?t=33244
Old 08-29-2016, 08:44 AM
Exhaust manifold -- $63.00 new at Messick's
http://www.messicks.com/part/15861-12313/manifold
Gaskets
http://www.messicks.com/part/15861-12350/gasket
Great find Billy...but we need some pics!
Old 08-29-2016, 09:35 AM
V30crewcab V30crewcab is offline
fuel shutoff is available here:
http://www.woodward.com/EngineSolenoidShutDownKits.aspx
doubt thats your problem though at that low hours. probably just goofy wiring or po mods.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 08-29-2016, 08:02 PM
Thanks for the help. Got the fluids changed. Engine oil looked like it never been changed and the hydraulic oil looked like milk. Another change in both and they should be OK. I mowed the yard and boy do the 60in decks spin fast.
Old 08-30-2016, 01:24 AM
TheSaturnV's Avatar
Originally Posted by Billy(OH) View Post
Thanks for the help. Got the fluids changed. Engine oil looked like it never been changed ....
The oil in my Cub diesel gets dark fairly soon after an oil change.
Old 08-30-2016, 04:56 AM
The Kubota Cubs are smooth too. Congrats.
Old 08-30-2016, 09:00 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Yup, its called a diesel lol. They do that
1- 1200 in pieces
1- 1864 in pieces
