Old 08-31-2016, 05:29 PM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Default China made Throwout Bearing
Getting ready to change out the clutch on a Cub 102 and thought I'd also change out the springs and throwout bearing.
Anyway I was looking at the Throwout and it reads China....It's packaged in a Genuine part package with Cub Cadet Troy-bilt Trade Marks.
Is this thing junk or is it good to go......thoughts please.
Old 08-31-2016, 06:00 PM
It's basically the only choice you have.....
Old 08-31-2016, 06:27 PM
Tom4981's Avatar
O.K. Thanks.
Old 08-31-2016, 07:44 PM
I run one of these but because it's longer you need the third pin that the spring rests against to be further back, I bought a new driveshaft from Jeff and drilled my own hole or you could use a split collar on your current shaft just to avoid having an extra hole.
http://ihccw.com/images/0901/IMG_2592_1.JPG
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-31-2016, 09:47 PM
john hall's Avatar
I will say that bearings in general tend to come from all over the planet. I generally prefer stuff made in USA or Europe. What I find interesting is that say Fafnir (just picking a name at random) may supply bearings made in multiple countries. I'm pretty certain I have gotten combine bearings from Deere that were made in China.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-31-2016, 10:09 PM
bocephus1991's Avatar
Unfortunately most everything is made overseas, and it sucks!!
Brian
Old 09-01-2016, 06:51 AM
Tom4981's Avatar
Once I get into changing everything out I'll a look at the bearing that's in it ......if it looks good I'll repack it and put it back in.
The cub 102 is about 50 years old and the clutch is worn pretty thin but not being the orginal owner I don't know if it's ever been changed out.
Thoughts Please..
Old 09-01-2016, 07:58 AM
Sad but true. Here is a pic of the CI rear in a GT3100 that I sold.
Old 09-01-2016, 08:07 AM
Tom4981's Avatar
Attachment 77784
Made between 2005 - 2010 3000 Series....Thanks for the posting.
Old 09-01-2016, 09:03 AM
Thoughts Please..
Don't do that. Just replace it. It's a PITA if the bearing fails later and you need to change it. I guess it's up to you, as it's your money, your time and your machine, but I wouldn't go to the trouble of disassembly and not change the t/o bearing.
