Old 09-13-2016, 08:51 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Default That had to make some noise!
I recently picked up a 1650 with this little gem of an engine. PO had engine rebuilt. OOOPs! This failure was not caused by launching of balance gears or lack of lube...I believe the rod was incorrectly torqued and/or sized. Kohler specs matter!
Queen Of The Quietlines!
Old 09-13-2016, 09:05 PM
Wow Beth forget about that being a window that's got to be considered a room!
Old 09-13-2016, 09:32 PM
Wow!
From the size of that hole, my guess is the high idle RPM was not set and the rod failed before the flywheel. I bet it was screaming!
Old 09-13-2016, 09:46 PM
Billy-O's Avatar
Billy-O Billy-O is online now
That's unusual for stock motors. Seen a couple blocks like that used in pullers.
Plow blade
#2 Cart
QA36 snowthower
Old 09-13-2016, 09:56 PM
I imagine, the PO needed a new pair of shorts after that!
Old 09-14-2016, 05:04 AM
Dirty Steve's Avatar
I agree with Allen. When that malfunction occurred it had to have left a mark somewhere...
