Old 09-17-2016, 06:14 PM
John147 John147 is offline
Default Hydraulic angle kit
Hi everyone, I recently picked this up off eBay. It was super cheap, being that the cylinder is crap, but it appears to be the early style. SO my million dollar question is this, the kit I can use a early style lift cylinder for? Most of these I've seen have a lot bigger bore cylinders.
Thanks in advance for everyone's help.
Old 09-17-2016, 07:46 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Whats wrong with the cylinder?
1- 1200 in pieces
1- 1864 in pieces
Old 09-17-2016, 09:18 PM
In and out stroke movement is frozen looks like it was filled with water at some point.
Old 09-18-2016, 10:00 PM
I picked up a lift cylinder from a 149 today it has about a 1 1/2" shorter stroke but should work till i can get this cylinder cut open and rebuilt or find a replacement. Tomorrow i am going to head down to the local hydraulic shop and see if i can get lines and fittings.
Old 09-19-2016, 12:08 AM
That cylinder has been cut open before. I can tell by the weld on the cap end.
I don't know that they ever used that small rod cylinder for the angle on a blade. If so, I'd like to see documentation (parts book) or otherwise. I think that might be an adapted QL cylinder.
If it's frozen in place, it will cost more to fix it than for someone to build a new one.... or about the same. The tube, piston and rod will have to be replaced. Don't let anyone fool you. A stainless rod will not work. It must be chrome plated. BTDT. It doesn't work.
Old 09-19-2016, 12:26 AM
This is my kit
http://ihccw.com/images/0804/IMG_1511_10.JPG
And this is the later style one
http://ihccw.com/images/0901/IMG_2197_18.JPG
I was going to ask the hydraulic shop the best option if they can get me a cylinder that will work that's fine. If not i will use use the lift cylinder.
Old 09-19-2016, 12:33 AM
That works. I guess yours just looks small. I've seen both of those kits.... I thought yours looked smaller.
Still, it's been apart before.
I'd be surprised if the shop even wants to take it apart to attempt a fix.
The thing about using the lift cylinder is that the smaller rod is more likely to bend or break if you run into something. You'll have to be careful.
Old 09-19-2016, 12:53 AM
I agree about them not even wanting to touch it, i am more hoping they might be able to get me something new with the correct size ends on it.
I only paid 60 shipped for the kit and i got the lift cylinder today for basically nothing so it's more of a why not try and make something work here deal.
I am installing it on a 42" blade and my driveways paved and it's only for light snows and clean up i have that 450 blower for the heavy work so i am hoping it will be alight.
Old 09-19-2016, 02:08 PM
At this point it's been pretty slow since kids went back to school to i decided to cut the cylinder open today before lunch. The Hytran did it's job the one side was full of moister soaked Hytran that dried out. The inside of the cylinder looks good and should clean up no issues. I am just having issues locating seals the shop I went was worthless.
Old 09-19-2016, 02:44 PM
Try these ppl.
I get all my seals from them, nice to deal with and they are a worldwide supplier
of seals for hydraulic needs.
https://www.mfpseals.com/?gclid=CICZ...FYI0aQod7IQOUw
They do have a minimum order so you might wind up getting more than you need, but you can't beat their prices.
I've gotten obsolete stuff from them, for old loaders/backhoes, plow cylinders etc.
Just order by size and style.
