Old 09-22-2016, 04:43 AM
yourshoesareuntied yourshoesareuntied is offline
Default Cleaning varnish out of gas tank
the internet tells me everything from acetone to drain cleaner..E85..(not available in my state) so what have you guys used that worked?
Okie 105 Project Album (Lots of pictures will be added as each section is taken apart, maybe it can help you get yours back together)
https://flic.kr/s/aHskC461kS
Old 09-22-2016, 06:21 AM
I have used Lacquer Thinner in the past and it worked well for me.
Old 09-22-2016, 06:26 AM
Tom4981's Avatar
Tom4981 Tom4981 is offline
I've never used the stuff but some people claim to have used CLR with good results.
Old 09-22-2016, 08:09 AM
I clean tanks at work with acetone, it works great and drys fast.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-22-2016, 08:41 AM
Lacquer thinner or acetone,
Throw in a handful of small nuts and or bolts.
and shake, shake, shake.
inspect and repeat if necessary.
Old 09-22-2016, 09:35 PM
Thank you guys, I happen to have a gallon of acetone leftover from a concrete countertop project.
Old 09-23-2016, 07:28 AM
rbarri2's Avatar
rbarri2 rbarri2 is offline
If the tank has any rust inside of it, consider using a phosphoric acid wash.
It will leave a black iron phosphate coating that protects the metal.
I'm in the process of cleaning a 19 gallon tank from a 67 IH Travelall using this method.
PLEASE CONTACT ME BY CLICKING MY USER NAME ABOVE.
1968 Cub Cadet 124 with deck and #2 Trailer
1965 IH Scout 80 Champagne Edition
1968 IH Travelall 4x4 and factory PTO winch
1955 IH Refrigerator
Old 09-25-2016, 02:55 AM
bocephus1991's Avatar
Vinegar works good on metal tanks, I've used it. Works great on bolts too!
Brian
Old 09-25-2016, 09:44 AM
twoton twoton is offline
I use denatured alcohol. Is this a metal tank? If you add nuts or gravel as some may suggest, I would be concerned about promoting rust inside the tank. Might be a good time to seal the tank while you're at it?
https://www.amazon.com/KREEM-Gas-Tan...em+tank+sealer
More reading on this;
http://www.onlycubcadets.net/forum/s...882#post340882
Old 09-25-2016, 01:44 PM
How do small nuts/bolts or gravel promote rust in a tank?? Its a non painted surface in there, it will rust only when water and air a present....... Has nothing to do with a cleaning method.
Tank liners can work, most don't. If they are applied correctly, and you buy good stuff, I have seen them work fine. I have also seen them peel and flake causing way more issues than they were ever worth. The OP didn't say the tank was leaking, so no need for them anyway. Don't ever line/seal a tank that doesn't need it.
