Old 09-24-2016, 06:41 AM
garynail garynail is offline
Default Brinly plow help
Hello, First post here. I'm trying to get a brinly plow set up on my 1450 and having a heck of a time. First question. Is the pivot hole for the crank depth adjustment supposed to be slotted or has this one been run loose and egged out? TIA Gary
Old 09-24-2016, 08:13 AM
bullockcm bullockcm is offline
I have never had mine apart but pretty sure from adjustments I have made that there is not that much slop in mine. Hole does look a bit egged out vs. being drilled like that. Might have to make a bushing, go to an oversized bolt, or probably last resort try to have it welded back into spec.
Old 09-24-2016, 09:03 AM
cubs-n-bxrs's Avatar
If memory serves me I think that there might be a bushing in that hole.
Old 09-24-2016, 09:16 AM
Default RE: Brinly Plow
Just to be clear in case my pic is too close in, this is the hole I'm referring to. (arrow in red) Thanks
Old 09-25-2016, 07:38 AM
Default Away we go
Thanks for the replies. I think I'll weld it and re-drill it. If I drilled it out and bushed it the center would probably be off to the side that is worn. I am going to guess that it is worn to the rear and either plug it and re-drill or just weld the back side of the hole and re-drill. You can't believe how much the geometry changes when moving within the limits of that hole. I'm trying to get this plow set up for a plow day, and am while setting it up as the Brinly manual suggests, I'm not even close to it working correctly. Thanks, Gary
Old 09-25-2016, 08:48 AM
I can't believe that egg shaped hole is giving you that much difficulty trying to set up your plow. Maybe you have something else going on presenting the problems you are talking about. I have been to a crap load of plowdays and have seen some pretty dilapidated plows doing a pretty fair job.
Old 09-25-2016, 01:26 PM
Merk Merk is offline
Can you post a picture of your plow?
I like to see a picture of your plow point and hitch adapter.
Can you post a picture of your plowed soil?
What type of soil are you plowing?
How many rounds have you made. First round should go around 2-4 inches deep.
Second round should be better
Third round should be the money maker round.
Is it sod?
Project Uncle Dick
Cub Cadet 70
Old 09-25-2016, 01:28 PM
Is it sod?
I agree with both these guys. I don't think that hole is your issue. It wouldn't affect it that much.
Old 09-25-2016, 01:42 PM
I check my Brinly plow......It has that slot. I make sure the bolt is ok. I've been plowing with that plow for 15-18 years with no issues.
Project Uncle Dick
Cub Cadet 70
Old 09-25-2016, 03:56 PM
You guys ever think of looking at the parts books??
Took me all of 30 sec to find it
That bolt is supposed to be a 1/2 x 1-3/4" w/hex lock nut
The bushing/spacer goes in the upper hole for the crank handle clevis
The spacer is 1/2" I.D. x 9/16"
Available from Brinly/Hardy
https://shop.brinly.com/assets/image...am_PP-51BH.pdf
