Old 09-27-2016, 10:26 PM
Ihquietline's Avatar
Ihquietline Ihquietline is offline
Default 1772 Hydro linkage adjustment
Hi everyone I've got a 1772 that I rebuilt the rear end due to the ears being broke off on reduction gear housing. Had to buy a cam bracket and the neutral return rod due to the one that was on it was broke. I've got it all back together and it drives good goes into neutral from forward to reverse at idle fine but at full throttle when I go from forward to neutral I have to go halfway into reverse then back to neutral to get it to stop. My question is what is the proper procedure to adjust forward and reverse and the neutral return? : Thanks in advance!
Josh
1979 Ih Cub Cadet 1650,1987 Cub Cadet 1811, 1989 Cub Cadet 1772, 2006 Cub Cadet Z Force 50, 1A tiller with both extensions, Sears 10 in.moldboard plow, Ih 54 inch snow/dirt blade, Agri Fab 42 in.lawn sweeper
Old 09-27-2016, 11:03 PM
The adjustment procedure it outlined in the manual.
Here is the link for your machine:
http://www.onlycubcadets.net/forum/s...ad.php?t=25397
I have not read that book, so if you can't find it, use this one. Procedure is the same, and I know it's in this one:
http://www.onlycubcadets.net/forum/s...ead.php?t=4644
It doesn't sound like it is out of adjustment, as much as it sounds like you still have play in the linkage somewhere. It may be both loose components, and adjustment.
Old 09-27-2016, 11:42 PM
Ok thanks I've got the pdf service manual for the 1772 but I couldn't seem to find the procedure in it I'll take a look again.
Josh
Old 09-27-2016, 11:52 PM
I seen you posted the service manual for the wide frame modelsbut for some reason it won't let me open it I'll try opening it later thanks.
Josh
Old 09-28-2016, 12:18 AM
Must be on your end. Opens fine for me.
Old 09-30-2016, 11:03 PM
I've tried opening either one of the links and it will not open tried on a two different computers and still no luck would one of the administrators know if something is wrong with my account not letting me open them?
Josh
Old 10-01-2016, 12:17 AM
Josh,
I have sent both manuals to the email listed on your account. Please download and save them to whatever device you choose.
I sent this information in the email, but will share it here also:
The manual for the later series machines (your machine) does not include the adjustment procedure for the hydro linkage. I'm sure it was a goof on CCC's part. The last manual I can find it in is the one for the 1X8/9 and Quietline manual. I also included that manual. The procedure starts on page 2-56.
Holler if you need anymore help.
Sorry you couldn't get them to download. It has nothing to do with your privileges or account. It's likely a setting on your PC/device. Or they may just be too large. Both files are pretty big.
