Old 09-30-2016, 07:41 PM
taylorjm taylorjm is offline
Default New from Michigan
Hi all. So I just came into a 2182 from about 1994. Not sure how to tell what year it is. It's a 141-742-100 21hp super garden tractor, sn 000817549. We bought a vacation house and I had the guy throw the tractor in. Starts and runs good except for the little click, click, click when starting every so often. It has a 60in deck and a 48" front plow. It has a rear pto and I think it's called a 3 point hitch. It has these two arms that stick out the back and I think they move up and down, though I haven't played with it much. The guy has some spare belts hanging in the garage and 3 old bearings which I'm guessing were from the deck. It does leak hydraulic fluid and it's coming from somewhere below the filter, but not the plug or the fitting near there. I can't for the life of me figure out where it's coming from, but from some pictures I think it might be from where the hydraulic pump meets the rear end. Maybe some winter I'll pull the rear end and fix it. I really don't have much lawn to mow and it's too much mower for me. It's like driving a tank on the lawn! The turn radius stinks on it! I have some trees that have about a 5' diameter base and it takes a 4 point turn to get around the thing! I spend as much time in reverse as in forward! It doesn't have very consistent speed either. Going up or down a hill or turning changes the speed a lot, so I'm constantly changing the speed, but I've never had a mower with hydraulics before so I don't know if that's normal or what needs to be fixed. If I was smart I should just sell it and get a riding mower! I'm not up there in winter so I don't need the plow, and the lot is only about a half acre.
Old 09-30-2016, 08:10 PM
Well a warm welcome to OCC!
Hope you stay a bit and learn, maybe share some info with us
Old 09-30-2016, 08:26 PM
JLM78 JLM78 is offline
Welcome for south Michigan
Old 09-30-2016, 11:59 PM
Welcome to OCC!
Old 10-01-2016, 12:44 PM
Whereabouts in Michigan? Saginaw here. You look like a cub collector!
Old 10-01-2016, 04:12 PM
Coldwater follow I 69 down to Indiana Coldwater 13 miles back form Ind.
