Old 09-30-2016, 09:12 PM
coinman66 coinman66 is offline
Default 1250 reverse weak
Reverse seems weak on my 1975 Cub 1250. It's like u have to pull it all the way down to get it to move. Is it just out of adjustment or something else? Forward seems fine.
Old 09-30-2016, 09:16 PM
Could be out of adjustment, but I'd rather think the reverse release valve isn't seating well.
Might take it out and clean it up, make sure it all moves freely.
Could also need a fluid and filter change.
God Luck with it.
If I had to bet, you have a worn trunnion. I have the same issue with a 149 and one of these days I'll get off my lazy but and fix it. Today is not the day, maybe one of these days.
Old 09-30-2016, 09:20 PM
Just changed fluid and filter, same results. I will look at t runnion. Which valve is is the reverse, sitting on tractor. Left or right?
Thanks
Old 09-30-2016, 10:58 PM
Here is my trunnion. Hydro is in neutral position.
