Old 05-23-2010, 10:42 PM
bobbyjupiter's Avatar
bobbyjupiter bobbyjupiter is offline
Question 125 Front Blade manual lift
Hello All,
Let me first say this site has been very helpful in my endeavors with my little yellow machine. Couple of questions...........
Someone posted me a front blade attachment guide (very helpful) the other day and I am still left with a couple of questions.
1) Where the blade subframe goes under the tractor and the forks go on the footrest bar I am encountering on the left side there is something bolted to the bar in the way and it is a rod like piece that goes toward the back and at the back it just looks like a big bolt head to the left of the rear end. So, what is this and what does it do? So I know whether to remove it or not.
2) Does the subframe to the blade click directly into the quick connect ....I mean do the two little ears or pegs that the pins go thru click into the quik slots or does the front attachment that was there in the quik link stay and somehow accomodate the subframe pegs any close up pics?
3) Since I'm asking Do most folks fabricate a lift rod or buy one? Is it gonna be hard to lift the blade up and down manually? Is this setup gonna be an effective way to keep my gravel on my driveway spread out evenly?
Sorry So many Questions But I do Thank you all. bobbyjupiter
Old 05-24-2010, 06:51 AM
#1 - How about posting some pictures of what you are talking about?
#2 - YES, the sub frame front mount pegs goes into the QA slots.
#3 - You can do either. For me, it is just as easy to fabricate one.
Simply run the tractor up on some 2 x 4 lumber, Place the the blade on the floor (not on the 2 x 4). Measure the distance between Point A and Point B. That is the length of the rod.
Old 05-24-2010, 10:53 AM
Thumbs up Much Obliged
Thanks, that answers some of my questions. I will try to post some pics of tractor and of object that is blocking the place on the footrest support bar that I need. In the mean time how much difference in width are a narrow frame and a wide frame subframe at the QA point?
Thanks Bobby
Old 05-24-2010, 11:07 AM
Click on this link........ Frames
