Old 10-06-2016, 12:49 PM
johncub7172's Avatar
Default Carb. cleaning question,...
I have a Crest 1000 watt sonic cleaner at work. We use it to clean steel tooling, and dies. The solution I'm not sure of, but it gets pretty hot.
My question is, does anyone with experience know if the carb. from my 125 would be safe to be cleaned this way in the sonic tank? Once the solution is up to temp., I usually leave tooling in for 30 minuts depending on what and how bad.
Thanks !
John
Old 10-06-2016, 03:32 PM
As long as the solution isn't caustic to aluminum, it will be fine.
Old 10-07-2016, 01:31 AM
Thank you J-Mech for your help! Gonna check into it tomorrow!
