Old 10-10-2016, 11:31 AM
taylorjm taylorjm is offline
Default Milky rear end fluid
I've seen on other posts of 2182's where people crack open the rear end and have milky oil coming out. Was there evidence of this on the dipstick or when draining the oil from the pump drain?
Old 10-10-2016, 11:56 AM
Terry C's Avatar
Terry C Terry C is offline
Both maybe.
If you are unsure of the condition of your rear end fluid just change it and the filter. It's cheap insurance and then you will know.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-10-2016, 12:00 PM
I would except I have a rear pto so it's a bit more involved than just removing the back plate. So I wondered if when you drain it through the drain plug, it shows it being milky. If it comes out looking ok from the drain plug, then can I assume it doesn't need to be opened from the rear end?
Old 10-10-2016, 12:04 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
milky means it has water moisture in it.
Pulling the drain for a half second will tell you if there is water (milky or actual water will come out first).
If only fluid comes out then put drain plug back in quick.
Old 10-10-2016, 12:12 PM
Ok, that's what I thought. I saw somewhere else that the wheel bearings/axles can condensate and hold moisture in them and most people drill holes to let the fluid drain back out. Do the axles need to be removed to get the moisture out of those or will the oil just drain back into the reservoir without the drain holes?
Old 10-10-2016, 12:24 PM
It will not drain, thus the need for the holes. If it would drain without them, why would there be a need to drill them??
The axles have to be removed to drill the holes.
Old 10-10-2016, 12:26 PM
If you drain it through the plug and it's milky you could always fill it with cheap fluid and run it till it's hot and drain it again, if you drain it while it's still hot you should get most of it out. Then you can install a new filter and good fluid.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-10-2016, 12:28 PM
Except what is in the axle cavity.
The rest is will work.
Old 10-11-2016, 09:33 AM
Dirty Steve's Avatar
Just pull all that non-essential PTO and 3 point set up and send it to me. Then you can get into the rear end easier.....
Old 10-11-2016, 10:27 PM
PaulS's Avatar
PaulS PaulS is offline
My son and I tore down a 2072 rear a while back. First the fluid at the bottom was a milky white indicating moisture. We then took the axle housings off and found about a half a quart of water in there. After a thorough clean up we drilled the holes to allow the trapped axle fluid to drain back into the rear. Runs great now.
