Old 10-15-2016, 07:18 PM
Default Not having a good day
It started at 7:00am this morning.
(A) OCC is not available
(B) At 3:00pm was doing some web surfing and got the infamous pop up, "your hard drive is going to crash in 5 minutes unless you call this 800 number" Got scared and started running Virus and malware scans. The Public Electric Utility decides to have a Power Outage in the middle of that.
(C) Got the power back now my Anti-Virus program is screwed up because it was interrupted in the middle of a scan. Had to fix that and re-run another scan.
(D) While I was waiting on the scan, decided to do some "trim mowing". I was within 5 minutes of being done, when bam..........Broken Wheel.
That is it, I give up. I know when I am beat. Going to stay low profile for the rest of the day and night.
Old 10-15-2016, 07:24 PM
Terry C's Avatar
Terry C Terry C is offline
Cubs in the shed are saying" If he would have just got up and took one of us for a drive, his day would be better"
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-15-2016, 07:31 PM
I had my 784 out mowing lawn, prior to trimming and had no issues.
Old 10-15-2016, 07:36 PM
Call it a day, have a cocktail and relax.
Old 10-15-2016, 07:52 PM
Tom4981's Avatar
Tom4981 Tom4981 is offline
I hope it's not contagious....I think I'll stay away just in case
Old 10-15-2016, 07:56 PM
Sorry to hear Roland.
Old 10-15-2016, 08:29 PM
john hall's Avatar
It ain't just you. I needed to work on the combine today, everything else got in the way it seemed. Dad wanted to mow some hay---he uses a Farmall Super A--6 volt. Thought the battery was going bad so we opted to change it with another one we had that was old but appeared to be holding a good charge. If you've never worked on one of these machines let me just say its an act of Congress to get the battery out. The replacement battery wouldn't sit low enough in the box to allow the ground bolt (which also connects the box to the dash and stabilizes the dash and steering) to connect, After a bunch of trying I had to "trim" the bottom of the battery case so it would drop down enough to get the bolts in. The battery actually rides on the bent up portions of the bottom of the case---we are talking about 1/8" clearance to get the battery in. Anyway I finally got it in, bolted down, and NOTHING. At this point I think it may be the starter switch. Regardless, the tractor has a hand crank so 1 turn and away it went, he went and mowed for close to 4 hours, I'll deal with the battery/starter issue another time. While he was mowing I pulled a wagon load of hay out of the shed. When I put it under there a month ago, I was a little close to one side. A couple bales were rubbing the corner post, I thought they would just slip by--nope. They pushed back on the load and broke the tailgate in 1/2. So, I get to make one of them tomorrow. And no, the combine still ain't fixed, just as well corn is too wet anyway.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-15-2016, 08:50 PM
Just think how much better tomorrow will go
See , it's all how you look at it.
Jeff
( the eternal optimist )
Old 10-15-2016, 09:00 PM
Originally Posted by john hall View Post
It ain't just you. I needed to work on the combine today, everything else got in the way it seemed. Dad wanted to mow some hay---he uses a Farmall Super A--6 volt. Thought the battery was going bad so we opted to change it with another one we had that was old but appeared to be holding a good charge. If you've never worked on one of these machines let me just say its an act of Congress to get the battery out. The replacement battery wouldn't sit low enough in the box to allow the ground bolt (which also connects the box to the dash and stabilizes the dash and steering) to connect, After a bunch of trying I had to "trim" the bottom of the battery case so it would drop down enough to get the bolts in. The battery actually rides on the bent up portions of the bottom of the case---we are talking about 1/8" clearance to get the battery in. Anyway I finally got it in, bolted down, and NOTHING. At this point I think it may be the starter switch. Regardless, the tractor has a hand crank so 1 turn and away it went, he went and mowed for close to 4 hours, I'll deal with the battery/starter issue another time. While he was mowing I pulled a wagon load of hay out of the shed. When I put it under there a month ago, I was a little close to one side. A couple bales were rubbing the corner post, I thought they would just slip by--nope. They pshed back on the load and broke the tailgate in 1/2. So, I get to make one of them tomorrow. And no, the combine still ain't fixed, just as well corn is too wet anyway.
Hey guys it's the full moon Jinx, nothing to do with your luck Ha,LOL!
I ran corn monday,tuesday and finished wed. it ran near 18% but it was short maturity, 95 day.
Too bad it is bringing just $3.00 a bu. ----
Old 10-15-2016, 09:40 PM
I know how you feel, Roland. Sometimes, it seems like a good idea to just stay in bed.
