Go Back   Only Cub Cadets > Resources > Technical Library - Tractors
Closed Thread
Old 03-25-2009, 12:48 PM
Default Brakes - Relining Discs
Here is the brake lining 3" X 3/16. You just cut it 8" long and then in half 1 1/2" then cut it 4" long and that will give you enough for one tractor. Here's what they looked like at the start.
Check this spot for too much wear. You may have to build it up with a welder and smooth or shape it back down to what its suppose to look like.
Just put that liquid plastic steel on it and put them in a vise overnight and your done.
Closed Thread
