I will be installing a "super steer" axle from an 1863 under my 782D which has the 3/4" diameter spindles. The SS axle is a 1" spindle. Is there a 1" ID bearing available that will fit into the bore of my 782D wheel/rim? Or, do I need to locate another set of wheels with 1" ID bearings? I'm sure this has been asked before, but I was unable to locate a previous post with this info after nearly an hour of searching. Thanks for your help!
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
I think your looking at something wrong.... or someone has been messing around. 782D should have 1" spindles.
![]() This is a good time to check part pics and compare part numbers (on your own). If you go look at an 1863 and a 782D they carry the same part number for the wheel bearings. |
Will do. Thanks. 782D axle must have been changed at some point.
At least the spindles and wheels were....
