Old 10-26-2016, 07:54 AM
SGragg SGragg is offline
Inactive Member
Default Coil Diagnosis
My 782 (serial #715729) has a Kohler K17 Series II (serial #24302). While mowing earlier this year, the engine started to sputter and loose power. I turned the PTO off and limped it back to the garage, where it died.
With the switch in Start position, it has power to and from the coil, but no power at the spark plug wires. I used an in-line spark plug tester and circuit/continuity tester. When key is in starting position (activating starter), no light in tester handle via plug wires.
I'm thinking dead coil?
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 10-26-2016, 08:25 AM
Did you check the points and condenser?
Old 10-26-2016, 09:11 AM
Inactive Member
Didn't. Will output from coil to plug wires only be achieved when the points contact?
Stanton
Old 10-26-2016, 10:54 AM
Well.... yes. The points are what makes the coil fire.
Old 10-26-2016, 11:13 AM
This should help.... KT Ignition Circuit
Old 10-26-2016, 11:55 AM
Inactive Member
Of course, that makes sense. Thank you both.
Stanton
