Old 11-19-2016, 01:04 PM
RustyYellow RustyYellow is offline
Default Hydro Relief Valve Question
Can one change from a manual relief to an automatic relief with no problems?
Is lengths different that makes one manual vs automatic, or internals?
Got a hydro that needs both valves, but company I found only have the automatic valves.
Mower these will go into is not a Cub, but it uses same Series 15, type U hydro.
Here's a pic of mower. 1990 Kut Kwick using Onan 20P as power. It's a commercial I use to mow 5 acres. Hydro is seen in 2nd pic. It's a beast and weighs in around 1,200#s.
'67 Cub Cadet 102 w/Kohler 10
'90 Kut Kwick CL20-60 w/Onan 20 Performer
'03 Craftsman GT5000 w/B&S 24 ELS
Old 11-19-2016, 02:15 PM
Short answer - Yes, with no problems.
Old 11-19-2016, 02:25 PM
Take your valves out (be careful not to get dirt into the pump) send them to this guy for a rebuild.
605 Furnace Rd.
Conneaut Ohio 44030
Phone: 440-499-5813
Email: mark.machtech@gmail.com
Normally a 7 - 8 day turn around and about $75.00 he has done a bunch for our members.
Old 11-19-2016, 03:54 PM
Terry C's Avatar
Terry C Terry C is offline
I have switched three tractors to automatics. Only problem is sometimes the tractor is not where I left it. They will roll away with autos in them.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-20-2016, 09:41 AM
john hall's Avatar
Trying to put my eyes back in--that machine looks like a slightly modern version of a Yazoo! I know you've been running it a while, just be careful with those things--I'm pretty certain the danger is why Yazoo disappeared. I'm certain its a mowing beast, turning corners are what scares me on them. Careful if you ever drive it with the deck off, seems to me it tries to turn into a catapult with the operator being the payload! The last one we worked on was a bit of a refurbishing--guy bought it not running. Anyway we got it going, sent it home and it dang near threw him off within the first 15 minutes of use. He got rid of it in a couple months. Hers a pic I lifted off the web of the style I was referring to. Good luck on the hydro repair.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
