Old 11-27-2016, 09:11 PM
DieselDoctor's Avatar
Default Lifting weights
I recently purchased a pair of wheel weights for a 12" wheel that are exceptionally heavy at 93 pounds each. They are over 3 1/2 inches thick. Being so heavy, I wondered how to get the weights installed on my 1882 safely without smashing some fingers. I came up with this simple tool to hang the weight while I installed the bolts. It is a 2' piece of 1/2" rod stock bent to engage the weight and hold it vertical. At the top end of the "hanger" I welded the eye from a 5/8 eye bolt. Using my engine hoist, I had precise control of positioning the weight into the rim and no smashed fingers! (yeah, the weights need paint!)
Old 11-27-2016, 11:09 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Nice jig! I have hung big tractor wheel weights like that before
Jay
Proud owner of the following:
Old 11-28-2016, 08:59 AM
The weights I have on my BX weigh 110 lbs. I use my engine hoist with a bar that I guide into one of the bolt holes in the wheel then I put 3 of the bolts in and snug them up, pull the lifting bar out and put the 4th bolt in.
Old 11-28-2016, 10:31 AM
I like the idea of the bar being a guide pin going into the first hole. I just may lengthen mine to work that way. Thanks Sam!
Old 11-28-2016, 11:02 AM
I pressed the pin into a 1/2" pipe that is about 3' long, the red strap slips over the pipe and hooks to the engine hoist. I balance the weight with one hand on the pipe and guide the pin into the bolt hole in the wheel. Made it with junk laying around the shop.
Old 11-28-2016, 12:07 PM
Merk Merk is offline
Same here..............
Project Uncle Dick
Cub Cadet 70
Old 11-28-2016, 10:13 PM
Nice Work DieselDoctor
Old 11-29-2016, 12:35 PM
Good job!
Old 11-29-2016, 03:51 PM
Jumper Jumper is offline
Great Job D. See, there's more to the North than just snow and taxes!
Old 12-01-2016, 05:26 PM
OldSkull's Avatar
OldSkull OldSkull is offline
What? Beer, strip club and Moose?
Gilles.
1963 100 (red)/in storage
