My rear tires on my HDS 3186 are 24X10.5-12NHS, Can someone help me figure out what size tires I can fit on the Cub. I am having a hard time finding these exact numbers.
Much appreciated Jim ![]() |
One option would be to go to a 23x10.50-12. You lose an inch in diameter, but only 1/2" in height of the tractor. It's a really common size. If you want to keep the diameter, you could go to a 24x9.50-12 and lose one inch in overall width. Those aren't as common though. My recommendation is to go with the 23x10.50-12s as they are very readily available and you keep the width, which helps with floating over the grass without as much compaction.
I think you will find that if you measure the height of the stock 24" tire there only 23" tall, any good quality 23x10.50 tire should be fine.
Great information, much help.
Thanks ![]() |
