Old 12-16-2016, 09:46 AM
Default Tire chain opinions.
My only set of chains just went out to my mother in law's on the 1050 so I need to order a new set for my 1211, I've always ran 2 link vbar chains and I've never had an issue with traction. While looking on the site I always buy chains from I noticed they also have diamond chains in vbar as well as duo chains in vbar, I'm leaning towards the diamond chains but wanted to hear some opinions before I pulled the trigger. Here's a link so you can take a look.
http://www.tirechain.com/23X10.50X12.htm
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-16-2016, 10:19 AM
Wish they had this style back when I bought my chains for my BX with the lug tires, V Duo Style Tire Chains.
What are you using for tires? If your running turfs I'd go for the regular V bar set.
Old 12-16-2016, 10:20 AM
Wish they had this style back when I bought my chains. V Duo Style Tire Chains.
Turf tires. I plow two of my neighbors driveways so I have to run on the road for a 1/4 mile or so, I was thinking the diamonds or the duo's would be a smoother ride.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-16-2016, 10:50 AM
Dirty Steve's Avatar
If I had turf tires without asphalt driveway I would be interested the studded diamond or the V-bar duo. Those studded diamonds are midevil looking!
Old 12-16-2016, 12:22 PM
Pricey too !!
Tim,
I have like 12 sets of chains of or such sorts here,but you are there and you were here.It is what it is.
Those v bars will work well on the 268.
I would stick with the 2 link chains.Mine are on their 5th season.
Up to 534 and counting...
Old 12-16-2016, 12:30 PM
Tim, on bigger tractors those chains are used for lugged tires....typically
Old 12-16-2016, 12:33 PM
Pricey too !!
Tim,
I won't buy used chains, last thing I want to be doing out in the cold is messing with broken chains. The set on the 1050 are 6yrs old and they still look new and I've done alot of plowing with them, I'm not to concerned about the price since there quality chains that will last. I got a set of Carlisle xtrac tires for the 268, they were $21 each.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-16-2016, 12:55 PM
there you go!!! 21$??!!!!.... i cant remember if one rides better than the other or not, but ill tell you now you better air those tires down to about 2-5psi because those chains do bounce...the diamond and duo style and thats on a full size tractor...will not stop forward momentum though...just keep going and going...never even seen vbar ones..cool link
i say get some cheap lug tires and get the studded diamond ones...look the best all around, and wont ever get stuck!!
Old 12-16-2016, 11:22 PM
I am kind of confused if you want these on a riding cub 1211 or a cub snowblower 268. If it is for your 268, then you really don't need chains since the rear tires have enough weight on them already. I have had my 268 for many years with snow over the top of the auger housing and never had any issues. For your 1211, if you have always used the V-bar and had success, then continue using them unless you just want change, but for a higher price! Never change a winning strategy.
Old 12-16-2016, 11:24 PM
this thread was to discuss chains for the 1211.
Pap's 100
Restored 108
1211 Dual Stick
1050
