Old 12-16-2016, 12:03 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default Time for brakes
We had a snowfall of 5 - 6" earlier in the week. the 1572 did a magnificent job in clearing it all out. When I was done, I just backed it into the garage and closed the door to let all the snow just melt away and dry up. This morning, I went out in the garage to get something out of the truck, when I saw a brake lining on the floor. Best as I can figure, as I was backing up, I stepped on the pedal to stop and the lining just rotated around with the rotor and wound up on the floor in one piece. What do you think is the best way to proceed with this? Just re-bond the lining to the pad after cleaning off the rust and debris? Go through and replace all the linings? What's the best thing to use to re-bond the linings?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 12-16-2016, 12:06 PM
taylorjm taylorjm is offline
I just finished buying new brake lining from McMaster Carr, drilling the rivets out of the old pads and using jb weld to glue the new pads to the metal. Haven't given it a real test yet, just installed them.
Old 12-16-2016, 05:02 PM
FrankF3's Avatar
Thanks. how will JB Weld hold up in this application?
Old 12-16-2016, 05:27 PM
Frank1541 Frank1541 is offline
JB Weld will hold up fine. I have did my brakes a couple of years ago using it.
John
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 12-16-2016, 06:22 PM
JB weld works just fine. BTDT.
Old 12-16-2016, 08:00 PM
twoton twoton is offline
http://www.onlycubcadets.net/forum/s...85&postcount=8
Old 12-16-2016, 09:30 PM
+4 on the JB weld. I put a light coating on the back side, stick them suckers in the vice overnight and the next day you are good to go....I mean stop.
Old 12-17-2016, 10:00 PM
FrankF3's Avatar
Thanks guys. I'll have to try and get to it over the next couple of days when no snow is in the forecast. Ever notice how this stuff usually happens at the worst possible time??
Old 12-18-2016, 10:09 AM
It is called "gotchas"
I swear the equipment talks to each other, seriously!!!!!!!!!
On days when we were short of tradesman we always had the most
breakdowns.
Also, when we would have a quiet night and things were humming along well,
all of a sudden the requests would start pouring in, and it was always not the normal things,always off the wall WTF caused that to happen stuff.
I could write a thick book!
I'm sure J. mech could tell stories also, as well as you other fellers in the "fixin' business.
But the roof don't leak if it don't rain Ha,LOL!
