Old 12-29-2016, 05:47 PM
inspectorudy's Avatar
Default Lost my key to my 1811
I can't imagine where I lost my ignition key but I did and now I am not sure if I have the original switch or not. Does anyone know where to buy a new set of keys? There are a lot of five post switches on Ebay but most do not have the same pattern that mine does on the back. I'm trying to not have to remove the switch if I can but am not sure what to do about a new key. Any advice?
Thanks
1811 Hydro
Old 12-29-2016, 06:15 PM
It just takes an Indak key. Nothing special. Most hardware stores or anywhere that sells small engine or mower parts stock them. Part stores too. No big deal.
Old 12-29-2016, 06:54 PM
There are more than one type of key they make,BTDT, looks like you can remove the switch, take it to the store, or buy a few and see if it fits and return the others.
Up to 534 and counting...
Old 12-29-2016, 10:53 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
My 2 1811's, snow blower and Scag all use the same key. Figured I should keep one handy.
Old 12-29-2016, 11:45 PM
Berwil's Avatar
Berwil Berwil is offline
Just use the flat blade screw driver in the knife. That way you won't have the weight of the knife trying to pull the key out as you bounce over the lawn.
Bill
Old 12-30-2016, 01:53 AM
Not in that style....
Yes, Indak makes more than one key, but not for the ignitions switches. They all are like this:
http://www.ebay.com/itm/like/2723206...&ul_noapp=true
Old 12-30-2016, 03:42 PM
One more question and that is the measurements of the CC 1811 seat pan bolt pattern. My old after market seat with a universal pattern has worn out and all I have to measure is the flip up mounting plate which looks like 11"W x 10"L slot. Anyone have a good model to recommend? BTW, I found the Indak key at my local ACE. He didn't actually sell them any longer but had one on a key chain that he didn't know where it came from and just gave it to me! I love having an ACE near my home. They are the best. I also went ahead and ordered a steel pan universal high back seat that said it will fit the 1811. It was $62 plus $22 shipping. I'll let you all now what it looks like. I am replacing the black seat that you see with the arm rests on it that I bought about two years ago. What a piece of junk! It sold for $99 and had free shipping but the vinyl fell apart in the second year and the arm rests were only for your arms if you were sitting in the seat. If you tried to raise up using them they broke. I had to weld them up and replace all of the cheap plastic components with steel so that they were usable.
1811 Hydro
Old 12-30-2016, 05:14 PM
I have the same seat you ordered on my 108, it's about 4yrs old and still looks new.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-30-2016, 06:30 PM
I have this one to put on my mp982.
http://www.ebay.com/itm/SEAT-FOR-IH-...QAAOSwsN9W~-pY
I put this one on my 882 4 or 5 years ago and so far it works great. I did have to drill the bottom to fit.
http://www.surpluscenter.com/Brands/...-1-3202-BK.axd
Old 12-31-2016, 08:21 PM
Wow! For a moment I thought you two were talking about the seat with the arm rests on it! What a piece of junk.
As it turned out several members here told me at the time I wouldn't get much use out of any type of arm rests and they were right. I do use it occasionally but not very often. I remember plowing long stretches as a youngster and always wanted arm rests but when mowing I am moving my arms so much there is no time for them on the rests.
1811 Hydro
