Old 01-09-2017, 10:45 PM
rocker582special's Avatar
rocker582special rocker582special is offline
Default Picking up a Farmall cub and curious what issues I should look for?
I'm trading away my 8N ford and 72" finish mower for a Farmall cub with a 60" woods mower under it. The tractor is in very good shape. Has new belts for the mower and has been converted to 12V. Only issue is the float in the carb is stuck. Other then that it runs. Just curious what else I should be checking for. Any help would be appreciated. Thank you.
Rocky
Cub cadet 70,123(parts),125,582Special
Old 01-09-2017, 11:17 PM
If you can you should do a compression test on the farmall, alot of times when a tractor has been converted to 12v its because its low on compression and 6v doesnt spin it fast enough to start it. The 8n has more HP and will be cheaper to repair in the long run, just saying.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-09-2017, 11:28 PM
Mike in SD's Avatar
Mike in SD Mike in SD is offline
I am as much of an IH guy as there is, but I would take the 8N over the Cub all things being same condition.
Mike
'62-O, 2-100, 71, 2-122, 2-123, 72, 127, 147, 108, 128, 149, 169, 2-1450, 582, 3-682, 2-782, 1811
1940 Farmall M, 1955 Farmall 300, 1967 Scout 800, Many Scout IIs, 1968 1200c 4x4
Old 01-09-2017, 11:57 PM
Congrats on the Cub.
We've got a 1956 with 60" mower, hydraulic lift. The wife uses it to cut our food plots.
Check, and likely clean out the oil bath air cleaner, most have been neglected over the years.
There hasn't been much of anything I've had to do to it, other than checking the oil, and filling it with gas. Ours is getting tired, but does what we expect it to do...
Have fun with it, and post up some pictures when you can.
Old 01-10-2017, 12:05 AM
Terry C's Avatar
Terry C Terry C is offline
I like your choice. Way too many Fords out there.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-10-2017, 12:43 AM
Thanks guys, my main reason for getting it besides being a cub/IH guy is that it's much easier to move from property to property from a mowing standpoint. I can haul it and my zero turn on the same trailer vs just the 8N and finish mower having to leave my zero turn behind.
Rocky
Old 01-10-2017, 12:53 AM
johncub7172's Avatar
Thumbs up
Mike
How right you are! We still have the family 8N that still runs good! I still love the Farmall cubs, though.
Old 01-10-2017, 01:46 AM
cub123's Avatar
cub123 cub123 is offline
Check over the castings for cracks or repairs, especially in the front where the axle mounts.
Old 01-11-2017, 03:02 PM
Amazing how things change quickly. I'm keeping the 8N, for awhile. Having vehicle issues so I'll deal with them. A better deal will present itself later.
Rocky
Old 01-11-2017, 07:58 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Mike
You won't get an argument from me. Nothing against the IH, but these Fords live on and do their jobs well.
Plow blade
#2 Cart
QA36 snowthower
