Old 01-17-2017, 10:19 AM
Shaner Shaner is offline
Default Cub cadet 1572 wiring harness?
Does anyone on here have a source to buy a new cub cadet 1572 wiring harness? I'm swapping in a D600 Kubota engine into my 1872 and I need a harness. Tried calling both of my local cub cadet dealers and they drew blanks. Thanks in advance.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 01-17-2017, 11:05 AM
Try our sponsors, or make one using part of the 1872 harness and adding the wires needed to it
I am sure Roland will help you out.
Up to 534 and counting...
Old 01-18-2017, 10:50 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
When I had my 782D, it used the wiring harness # 725-3086 which I got from Porch Electric. It was well made and went right in. Now the 1572 uses harness number 725-3132 and is basically the same harness as the 782D EXCEPT for the fact that the 782D harness does not have provisions for the rear PTO And also does not have the added length of the wire runs to the rear to account for the extended frame. Janet was very flexible when I was getting the harness from them. I'm sure they could work with you on this.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
