Old 01-31-2017, 11:32 AM
hotrod5337 hotrod5337 is offline
Default Found another $100 2544.
Yeeee hawwww here we go again. Lol
Old 01-31-2017, 11:49 AM
Carnage...
Old 01-31-2017, 12:46 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
It appears to have been run with too little oil!
Queen Of The Quietlines!
Old 01-31-2017, 01:11 PM
Made $1900 on the last one I bought with scrap bottom end. The guy didn’t tell me it had blown up but for what I paid I didn’t bother calling him back up. haha Fortunately the block wasn’t damaged and I was able to find a used crank on fleabay, 2 new rods and the gaskets I needed for 125. Used crank was in good shape I polished the journals, quick hone job and back together it went.
This one was sold to me with the blown motor. Ive yet to find anything wrong with this block either so maybe I can find another good used crank.
I noticed after I got the first 2544 back together that the oil drain was leaking pretty bad after I added the oil. I never took it loose so im assuming it originally leaked down to the point causing the bottom end to seize. The wire for the low oil sensor was also disconnected. Those plastic drains are a recipe for disaster. ended up using a standard pipe plug
oddly enuf the cylinders in this engine and the other one were perfectly fine. no scoring at all. both machines 3-400hr range
Old 01-31-2017, 01:32 PM
DeltaCub's Avatar
Command cylinder bores are very durable. Kohler uses a nickel silicone process for incredible durability.
