Ok guys, I need to figure out if I should part or sell the 782/w attachments and what kind of price.
-782 IH model series 1 engine but strong. Re-bushed front end so very tight. Also bushed lift bar. Has extreme's extended sleeve hitch with static and floating straps. Plus stock and extended length lift pins. v61s on the front. Older lugs on the rear (filled). Tripletractor LED lights. Seat not great. one footpad let go - Front blade with hyd angle. I need to clean up the moldboard. great cutting edge. 1/4x 2.5. Adjustable lift rod. (I made it) - Tiller. I think I even have an extra long belt. Works great but a little ruff from sitting outside recently. I have the belt cover painted up and ready. - Mower deck and mule. 50C no holes in the deck. good blades. Cover is off to clean it up. - QA42 in great condition. Changed drive sprocket 1 or 2 teeth larger while reworking and oiling it to increase auger speed. Adjustable pulley as well. Have both straight upper arms for NF and angled for WF. Auger has a little paint worn off from snow use last year. stays in shed. Adjustable lift arm on it as well. I have electric chute control parts but mount is not built yet. Would do so if enough $$$ increase. - IH plastic weights. One has a crack now and a couple marks from my son bumping things. - Chipper/shredder attachment. Home grown adaptation. - 2 port valve body. From 2072. worked fine. Yellow in the pic. - set of tire chains. Have wear but a lot left in them. (no pic handy) |
Missed a pic of the tractor from today and need to add I have a bagger attachment with a motor. May have to set it up and take pics.
I would say, with all of those implements and condition that it should easily be in the $1000 to $1300 bracket. Looks to be in great shape, as well as your implements. My vote is that you keep it!! Looks like you already have someone very interested in it already and would someday like to call it his own.
Sure wish I had my dad's 106 cub cadet!!!........Food for thought. Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
I wish I had a choice. Sold the tractor and tiller.
