Old 02-02-2017, 06:56 PM
hillscubs hillscubs is offline
Default 149 racing
I have a 149 I purchased with the k321 they said it had recently been rebuilt. The throttle is wild on it cant control rpms other than at idle. it idles fine but when you give it some gas it just takes off rpms just keep climbing until you put it back to idle. Anybody have any ideas could it be a bad governor?
Old 02-02-2017, 07:01 PM
cubby102's Avatar
cubby102 cubby102 is offline
Adjust the governor linkage.
Old 02-02-2017, 07:09 PM
sorry I should have said that Ive adjusted the governor arm doesnt seem to make any difference.
Old 02-02-2017, 07:23 PM
You've adjusted the linkage, or the arm on the governor shaft? Did you rotate the shaft counterclockwise?
If so, then it's time to open it up. The governor gear is likely in a heap in the oil pan.
Old 02-02-2017, 07:47 PM
thank guys I always appreciate the knowledge you have. I will get busy tearing it down.
Old 02-02-2017, 07:50 PM
FWIW, you can get the governor out without complete disassembly...... but you have to be patient.
Old 02-02-2017, 08:08 PM
Setup of the linkages that control the engine speed should look like this. I have seen springs attached to the carb, also strings used as a throttle....
Up to 534 and counting...
Old 02-03-2017, 09:41 AM
J-mech means like this!....
Good advise to replace the governor at rebuild
Old 02-03-2017, 07:16 PM
Default 149 update and questions
I took the 321 apart today and it had been rebuilt very recently. the governor
was not broken up but it was not on the shaft it was tipped sidways and the cam gear was chewing away at it. My question is when i replace the governor will the new one do the same thing or did they just not install the first one correctly. also they didnt install the main seal correctly so it was leaking so I decided to tear it down all the way and do things correctly.
Old 02-03-2017, 07:36 PM
It probably fell off the shaft while rolling it around to assemble it, and before they got the cross shaft in. It's just one of those things you have to watch out for. The new gear should be fine. It does have the Philips head screw (gov gear retainer) installed doesn’t it? I don't trust the retainer. I install the cross shaft and use a piece of tape or something to hold it until I get the arm and carb on.
