Old 05-28-2010, 07:35 PM
cub1200puller's Avatar
cub1200puller cub1200puller is offline
Default Still no charge!
New regulator, new S/G, new wire and still wont charge. The A/G charges when field wire is grounded like the test shows. When you turn the key off the S/G keeps turning the motor over. Wired the way the service manual says. What NEXT?
Old 05-28-2010, 10:47 PM
It would help a lot if we knew what model of Cub you are talking about..!!
Old 05-28-2010, 10:50 PM
Its a cub cadet 129. Ive tried every thing and I did replace with the right 3 wire regulator. Could it be the points in the regulator are out of adjustment. If so, what is the gap suposed to be.
Old 05-28-2010, 10:55 PM
Amigatec's Avatar
Amigatec Amigatec is offline
What do the terminals on the VR say?
If you have anything hooked up the the L term it will do that. Use just the B,G, and F terms.
Pat Benner Haskell OK
Old 05-28-2010, 11:05 PM
Regulator has no L terminal. It has a bat, gen, F, and a ground comming out of the back. It was a direct replacement for this model tractor.
Old 05-28-2010, 11:09 PM
Amigatec's Avatar
First is a NEW 4 wire VR Look closely at the terms. The one on the back is marked G.
Second is my old VR the term on the back is the ground, the new ones don't have a Grd term.
If you wire the VR like the original, with the G wire attached to the L term, the SG will continue to run. DO NOT attach anything to the L term.
The last is also a 4 wire VR the term on the bottom is the G term.
The terms are marked L=Load, A=Armature, B=Battery, F=Field
Use only the A, F and G terms. I went through this just a few months ago.
Old 05-28-2010, 11:10 PM
Sounds like something is NOT wired right or some shorted wires.
Is it wired as per the diagrams in the Tech Library Section...???
Old 05-28-2010, 11:14 PM
Neither the 3 or 4 terminal V/R had a Ground terminal. The grounding is done through the Mounting Feet.
The G terminal is for "Generator"
Old 05-28-2010, 11:18 PM
Amigatec's Avatar
My old VR did have a Grd term, it was marked ground, and it was grounded, it was probably as old as the tractor is.
The old VR was a piece of rust.
Wide Frame Wiring Dia, it does show a Grd term, but that VR is NLA, just make sure you match the wires to the correct term.
Old 05-28-2010, 11:22 PM
It is wired as in the service manual. The terminal coming out of the back says grnd. and is hooked to the ground strap that grounds threw the body of tractor. I ran New wires the way the diagram showed. I had someone look at it and I think he adjusted the points gap. Now it doesnt stick but it only puts out 12.5 volts wich is the same reading as the battery by its self.
