Old 02-16-2017, 12:19 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default YET Another Driveline Question
I know this has been talked over ad nauseam on the forum and the diesels are hard on the driveline, but I am looking for advice on the driveline as it pertains to the rear PTO. While doing the driveway over the last few weeks, I noticed the driveline has been getting louder and louder on my 1572. Since I was in-between multiple storms I just rode with it. Now that I have a breather, I spent last nite to take the driveshaft and clutch for the rear PTO off of the 1572 before it rattles itself apart. Luckily I did, the safety wire must have snagged something and broken. It was found amongst the oily grass clippings on top of the rear-end. When I get the parts and have it fixed, I'll throw it back on.
A little history on my 1572, it has had the rear-PTO installed since it was new back in 1987. It also has had this section of the driveline repaired or replaced at least 3 times. One time this repair was done at the dealer, who told me one roll started walking out and as it gradually walked out, it was shaving a groove in the tunnel on the bottom of the fuel tank.
So time has come again to service this section. There must be a better design than what is used. Having the weight of the rotor of the rear PTO clutch spinning on this shaft with the pounding away at it as it runs is like having a remote flywheel. There has to be a better way. Any ideas for absorbing a rotating loading shock on this shaft?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 02-16-2017, 12:35 PM
Do you use the rear PTO??
Old 02-16-2017, 01:27 PM
FrankF3's Avatar
Yes, a couple times a year - at least. Tilling with the 48" Haban and clearing the field with the Rotary cutter.
Old 02-16-2017, 02:02 PM
Only suggestion I have is to add a harmonic balancer on the shaft running to the PTO. Room might be an issue, but it would absorb some of the shock load. Only other suggestion would be to remove the shaft when not in use.
Still running rag joints on the front shaft right?
Old 02-16-2017, 02:08 PM
CubDieselFan's Avatar
CV joint conversion from a 1864 would help.
Old 02-16-2017, 02:20 PM
The OP is talking about the short shaft that runs from the back side of the pump to the rear PTO, not the main drive shaft. To the best of my knowledge Oak has more info on this area. I'll PM him to check in on this one.
Old 02-16-2017, 03:18 PM
FrankF3's Avatar
Jonathan, I converted it about 2 - 3 years ago to run CV joints, but it had problems with that rear PTO shaft a couple of years before I did that. Space is pretty limited between the backside of the pump and to where the clutch is situated. I was thinking about a harmonic balancer too, but there's no room in there. Don't forget to take the rock shaft and the fuel tank into account too.
Old 02-16-2017, 03:59 PM
10-4, I did not catch that.
Old 02-16-2017, 07:15 PM
It's a poor design in my opinion. Too many pieces are in the shaft and are pinned together. Here are the pieces just to make the short shaft from the rear of the hydro to the bearing assembly that the pto is mounted to.
Here is what the shaft looks like. The pins wear the couplers so that the holes get egg shaped and then the shaft hole gets worn and the pin gets loose and the safety wire is the only thing holding it in place.
I have purchased all new couplers from Surplus Center but the one that attaches to the rear of the hydro is splined on one end and needs the other side machined out for the short shaft. I have talked to Jeff about this a year or so ago but never went any further.
I often wondered why the shafts couldn't be welded or at least leave on pin in just incase you hit something and needed a shear pin
Old 02-16-2017, 07:17 PM
You don't need a shear pin.
I'd just weld that shaft together. That would help.
Tags
rear pto
