I set up my 1050 for garden duty. I hate plowing with big fat tires. Sure, it floats a bit better, but the skinnies fit the dead furrow so much better and I think gives you better ability to steer within the furrow. I have 6-12's on the rear only because they were sitting and the tread works ok for plowing. I want to go to 8.50 lugs on the rear.
What do you think? Don't make fun of my rusty tractor, lol. I'll paint the rims before I mount up a set of tri-ribs. 20170220_161339.jpg On a second note, why is it that the simplest of things take so dang long?!?!? Took me nearly all day to take those spindles off a QL I have. I just wanted to easily put the narrow tires on the front, and I don't care that the spindle is the 3/4" one. I'm not carrying weight on the front, so NBD to me. The king pins were stuck on the QL, and one on the 1050!! Oh well. It's done now! And the front end on the 1050 is lubed up good and working well. Even turns stop to stop!! I'm happy, but I'll be happier when the rims are painted and a new set of tri-ribs installed! |
Why did you put your wheels on upside-down and backwards
![]() I would personally have put the 23s on the front and then mid mounted the plow, that way your dead furrow would never interfere with the hydraulic thermostat you installed from your old 1923 VW bug. But hey... whatever
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
I thought of that, but I don't think the ratio would be right with the front wheel assist I added if I put 23's on the front. I'd end up pulling the plow instead of pushing it. That never works. Evertime you push from behind while plowing deep, you end up with little plow pieces everywhere.
You could have put bushings in the front rims for 1''I had a bunch of Brinly yellow wheels with 1'' bushings that would fit older rims.
Bushings or bearings Mike?
Bushings like the Originals had but 1'' bore
I'd rather have a bearing. Besides, the 3/4" spindles are NBD with only a K series single under the hood. I'll keep that in mind though!
Not bad! Truthfully I think the three quarter inch front spindles would carry about as much of a load the one inch spindles would using implements. I like seeing the land plough set ups! One day I'll dig in to the action!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
Id like to see a on-land hitch setup. Think it would be cool and more fun to operate
