Old 03-08-2017, 08:05 PM
landon1986 landon1986 is offline
Default IH 782 Rear end / tranny leaks
I'm a new IH 782 owner trying to fix a few leak issues. I noticed a hydraulic oil leak coming from the rear end / tranny. I replaced the rear cover gasket, making sure the rear plate was flat and there were no burrs on the cast iron rear end mounting surface. I used RTV on the mounting bolts and torqued them properly. The rear end still leaked. I noticed that the transmission was wet in the filter area. I replaced the filter and bypass line, thinking that the fitting was leaking. The rear end / tranny still leaks! Is there another common leaking spot I should check? I don't believe the rear cover is leaking again. I think there is a leak in the tranny area and the oil is running down and dripping off the bottom of the rear cover, but I'm not 100% sure. Any help is greatly appreciated. Thank you.
Old 03-08-2017, 09:12 PM
Terry C's Avatar
Terry C Terry C is offline
You will need to check the relief valves and the cork gasket between the Hydro and the rear end. Remove the tunnel cover and observe where it's coming from.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 03-09-2017, 12:41 AM
johncub7172's Avatar
Any leaks from the charge pump lip seal?
Old 03-09-2017, 04:47 AM
Dirty Steve's Avatar
Welcome to OCC!
Might be time to pull the seat off and the fender pan off if you have not already. Then post some pictures.
Old 03-09-2017, 07:58 AM
I would remove the fenders and degrease and pressure wash the rear end, being clean will help pinpoint the leak but it is most likely the cork gasket or the relief valves.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 03-09-2017, 09:22 AM
Bamafan Bamafan is offline
Inactive Member
what they all said. I had the same problem on my 1450. I bit the bullet and tore it down and replaced the cork gasket another thing to check is if your tractor has internal brakes, check for a leak in that area if you suspect one while you have it down is to replace the o-ring.
[B]Larry[/B]
Old 03-11-2017, 05:52 PM
Default Many thanks and photos
Hey guys. Thank you very much for starting me off in the right direction. I took a few photos for you to look at. One is the relief valves and the other is under the tractor. Please let me know what you think. Your help is much appreciated!
Old 03-11-2017, 07:07 PM
Landon as others have stated you have to pressure wash thoroughly top to bottom after removing fenders to identify any leaks.
Old 03-11-2017, 08:29 PM
Yep. Seat and fender pan off. Then you can make it all pretty.
Old 03-12-2017, 08:05 AM
Here is a good thread by member Zippy doing pretty much the same things you should do on your 782.
http://www.onlycubcadets.net/forum/s...ad.php?t=47510
