Has anyone come up with a clean way of filling a hydro rear axle that fills thru the dipstick tube? If you fill too quickly it traps the displaced air until it burps blowing oil all over. Last one I did, I used an old squeeze bottle from a liter of 90W gear oil. I was able to force Hytrans in and then allow the air to escape back into the bottle, but it still created a big mess. I'd be interested in hearing how others do this.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
Some guys run a small rubber line (maybe 2 cycle fuel line or something similar--as big as you can) through the funnel into the rear maybe a couple inches deep--helps if it was coiled up so it will try to curl up and out of the way of the stream of oil. This does a good job of letting air out. Also seen a pipe union (can't think of the correct term) welded to the rear cover plate kind of high up. This is the kind of "improvement" folks do when they have the back cover off for work or to completely clean out the inside of the rear housing.
a piece of 3/16 brake line up through the funnel to let the air out but it's still slow going a real [PITA]
I installed a vent. Got the idea from Sam Mac.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 ![]() ![]() {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
The vent trick works very well! I have also done it up high like john said in the rear cover on the cast rears. That works too!
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
Removing the one of the bolts that hold the trans to the frame works also.
![]() Quote:
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Thanks for all the great suggestions. For now taking the bolt out sounds like the best bet. I plan to do a refresh on the entire tractor at some point later this year and will drill and tap for a vent when I have the axle out.
![]() Quote:
When I put fluid in my 1863 earlier this week I took some 3/16 id vinyl tubing, drilled 2 holes in the lid that fit the tubing and set the 2 gallon jug on the fender. The tube on the left is long enough to go from the bottom of the jug to the dipstick tube. The tube on the right is only about 5 inches long, it vents the jug and I blew in it to get the fluid started siphoning. The holes are sized to make the tubing fit tight. It took most of the day for it to siphon into the trans but I had other stuff to do anyway. There was about an inch left in the bottom of the jug because the tubing curled up some. I put it in with a small funnel but at least I didn't have to do the whole jug that way. I threw the jug away or I would set it up and make a better picture.
Cannon |
